简介
The XLR connector is the point where the XLR cable is inserted into the microphone. The XLR cable then carries the sound to the amplifiers.
你所需要的
Holding the microphone connector in one hand and the microphone base in the other, line up the screw in the connector with the hole in the middle of the microphone.
Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
After installing the connector back into the microphone, it should be ready to connect to any XLR cable.
4等其他人完成本指南。
7条评论
Hi. I have followed the steps to #3. “Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight. “ However, the connector does not stay in place. It is still loose where the connector moves inside the microphone. I cannot get it to sit tight .
Are the threads on your screw stripped?
Hi I have lost the screw in the side of the mic. Can you tell me the size of a replacement or where I can get one. Thank you
Chris Hall - 回复
I would take your microphone into your local ACE and see if they can help you find the right size
