跳转到主内容
Shure SM58 XLR Microphone Connector Installation Replacement
你所需要的
  1. Shure SM58 XLR Microphone Connector Installation Replacement, XLR Microphone Connector Installation: 步骤 1 中的图像 1,1
    • Holding the microphone connector in one hand and the microphone base in the other, line up the screw in the connector with the hole in the middle of the microphone.
    • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
  2. Shure SM58 XLR Microphone Connector Installation Replacement: 步骤 2 中的图像 1,1
    • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
    • Do not push the microphone past this point or the connector may become stuck.
  3. Shure SM58 XLR Microphone Connector Installation Replacement: 步骤 3 中的图像 1,1
    • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
结论
After installing the connector back into the microphone, it should be ready to connect to any XLR cable.
4等其他人完成本指南。
Ronald Lam
于09/27/12注册
307 声望
撰写一个指南
团队
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G53
5 名成员
创作了20篇指南
7条评论
Hi. I have followed the steps to #3. “Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight. “ However, the connector does not stay in place. It is still loose where the connector moves inside the microphone. I cannot get it to sit tight .
Joe Lee - 回复
Hi. I followed up to step #3. However, the connector does not stay tight. It keeps on moving inside with a little push.
Joe Lee - 回复
Hi. I followed up to step #3. But, the connect is still loose… Moves inside the microphone.
Joe Lee - 回复
Are the threads on your screw stripped?
Daniel Berger - 回复
Hi I have lost the screw in the side of the mic. Can you tell me the size of a replacement or where I can get one. Thank you
Chris Hall - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 10,527
