当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
4等其他人完成本指南。
7条评论
Thanks for this. I had a connector where the screw had come loose and the whole assembly had released and become jammed halfway into the housing, with the 3 prongs halfway exposed. I couldn’t quite figure out what was going on with it because it was really bound in there tightly, but your guide helped me sort out what was wrong, remove the connector assembly, and get it reseated properly in the mic housing. Thanks again!
Hi, I am trying to troubleshoot a very old 58, and the xlr connector screw wont stop turning (anti clockwise) and connector still wont come out. What should I try?
The retaining screw at the bottom of the microphone is gone and I am searching for a replacement. What is the specific name of the screw? Thank you!
It’s a grub screw. Just get hold of a Switchcraft Male XLR plug, either new or from an old mic cable, and and remove the screw. Remember the thread is reversed from a normal screw, which is why this is the best way to get a replacement.
