跳转到主内容
Shure SM58 XLR Microphone Connector Disassembly Replacement
你所需要的
  1. Shure SM58 XLR Microphone Connector Disassembly Replacement, XLR Microphone Connector Disassembly: 步骤 1 中的图像 1,1
    • Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
    • The retaining screw is mounted to the connector and has a left-handed thread. Turning the screw clockwise locks the connector in place. Turning it counterclockwise lowers it down into the hole, releasing the connector.
    • Once the screw stops, do not try to loosen it further.
    Its an old microphone, I'm not the first owner. The screw keeps going infinite and not enough to the connector to come off. What can I do?
    nunoandrade - 回复
  2. Shure SM58 XLR Microphone Connector Disassembly Replacement: 步骤 2 中的图像 1,1
    • Plug an XLR cable into the loose connector.
    • While holding the disconnect button down, pull on the cable to remove the connector from the body of the microphone.
结论
After installing the connector back into the microphone, it should be ready to connect to any XLR cable.
4等其他人完成本指南。
nat coll
于09/27/12注册
642 声望
创作了14篇指南
团队
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G53
5 名成员
创作了20篇指南
7条评论
This helped me fix a mic where the screw was not properly raised into the mic body. The XLR plug had been turned. With this information I was able to figure out how to remove the XLR plug, line it up, put it back in and properly raise the screw to hold it in place.
Tim - 回复
Thanks for this. I had a connector where the screw had come loose and the whole assembly had released and become jammed halfway into the housing, with the 3 prongs halfway exposed. I couldn’t quite figure out what was going on with it because it was really bound in there tightly, but your guide helped me sort out what was wrong, remove the connector assembly, and get it reseated properly in the mic housing. Thanks again!
Matt Levine - 回复
Hi, I am trying to troubleshoot a very old 58, and the xlr connector screw wont stop turning (anti clockwise) and connector still wont come out. What should I try?
nunoandrade - 回复
The retaining screw at the bottom of the microphone is gone and I am searching for a replacement. What is the specific name of the screw? Thank you!
Kara Taylor - 回复
It’s a grub screw. Just get hold of a Switchcraft Male XLR plug, either new or from an old mic cable, and and remove the screw. Remember the thread is reversed from a normal screw, which is why this is the best way to get a replacement.
Keith Turner - 回复
Which prong (looking at the bottom of the microphone where the 3 prongs form a triangle Left-Center-Right) is supposed to be connected to the outer shield of the microphone cable (XLR) and which prongs connect to the other two wires running inside the cable?
Les Blachut - 回复
If you look carefully at the pins they are numbered 1 2 3. The connections are:-
Pin 1 = Shield/Ground
Pin 2 = Red
Pin 3 = Black
If the wires are a different colour, there will usually be one which is black , and if not the mic will still work ok even if the two wires are reversed, it may be out of phase with other mics, but that will not be noticeable in most uses.
Keith Turner -
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 20
过去 30 天: 71
总计 15,068
