跳转到主内容
Shure SM58 Grille Replacement
  1. Shure SM58 Grille Replacement, Grille: 步骤 1 中的图像 1,1
    • Hold the microphone just below the grille with one hand while using your other hand to rotate the grille clockwise to remove.
  2. Shure SM58 Grille Replacement: 步骤 2 中的图像 1,2 Shure SM58 Grille Replacement: 步骤 2 中的图像 2,2
    • Completely unscrew the grille and slide it off of the top of the microphone. The unprotected microphone is delicate, so place it somewhere safe while you follow the next steps.
结论
Follow the steps in reverse to install the new grille on the microphone.
5等其他人完成本指南。
nat coll
于09/27/12注册
642 声望
创作了14篇指南
团队
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G53
5 名成员
创作了20篇指南
2条评论
Can you change the grilles of sm58 and sm86?
Jack - 回复
Hello, I have two SM58 (wired), No matter how I tried to remove the grill from one of them, It just would not budge. With the other one, The grill comes off, but the base refuses to unscrew. Can you tell me how to solve this issue? Thanks in advance.
junia joseph - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 35
总计 10,022
