当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Hold the black plastic piece under the grille in one hand. In the other hand, hold the microphone collar.
Slowly, pull upward while twisting the black plastic piece clockwise.
Never open the microphone capsule. Attempting to repair the capsule will result in permanent damage.
7等其他人完成本指南。
5条评论
Thanks for that,
Can i just replace the capsule as seen in the last picture?
Has it to be resoldered? Where do those very fine copper wires go?
It's been a few years since I made the guide and no longer have any microphones nearby to examen, but if I remember correctly, there is no soldering between the capsule and the housing. I believe the housing is soldered to the rest of the body with the silver leads at the bottom left of the picture.
You can unscrew just the grill.
