跳转到主内容
加入维修社区 - 创建账户
Shower Handle O-ring Replacement
你所需要的
  1. Shower Handle O-ring  Replacement, Shower Handle O-ring: 步骤 1 中的图像 1,1
    • Be sure your water main is turned off, preventing water flow to your shower.
    • Using your flat head screwdriver, remove the screw from the middle of the handle.
  2. Shower Handle O-ring  Replacement: 步骤 2 中的图像 1,1
    • Use your groove joint pliers to loosen and remove the escutcheon plate.
  3. Shower Handle O-ring  Replacement: 步骤 3 中的图像 1,1
    • Using your groove joint pliers, loosen and remove the cartridge stem.
  4. Shower Handle O-ring  Replacement: 步骤 4 中的图像 1,1
    • Slowly unscrew and remove the stem completely.
    • There may be some water leakage due to built up pressure.
  5. Shower Handle O-ring  Replacement: 步骤 5 中的图像 1,2 Shower Handle O-ring  Replacement: 步骤 5 中的图像 2,2
    • Using your flat head screwdriver, remove the screw from the end of the stem cartridge.
    • Once the screw is removed, replace the damaged O-ring with the new replacement O-ring.
    • When installing a new O-ring, be sure the O-ring has a tight seal to prevent further leaking.
    • Once reassembly is complete and all parts are snug, turn the water main back on to allow water to flow to the shower again.
终点
3等其他人完成本指南。
团队
Michigan Tech, Team 1-6, Lauer Spring 2016 Michigan Tech, Team 1-6, Lauer Spring 2016 的会员
MTU-LAUER-S16S1G6
1 名成员
创作了1篇指南
4指南评论
This fixed the dripping shower head but now my shower handles are tight and difficult to turn and the water pressure is affected after replacing the o-rings. What could the issue be?
Cin - 回复 分享
Try putting petroleum jelly all over the outside of the stem/cartridge (including the threading/grooves) before screwing it all back together. That will keep your handles turning smoothly, and easily.
It's the plumbing equivalent to WD40.
Jess - 回复 分享
As for the change in water pressure, I'm not sure what that would be. Did you use the same size O-ring?
Jess - 回复 分享
I have the same handles and stems, but leaking not from the rubber. Leaking occuring when tuning on the handle. Do you know where to find the parts?
Phil Yue - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 42
过去 30 天: 192
总计 25,965
