跳转到主内容
加入维修社区 - 创建账户
Shower Glass Silicone Replacement
你所需要的
  1. Shower Glass Silicone Replacement, Shower Glass Silicone Replacement: 步骤 1 中的图像 1,1
    • Make sure the area is dry and clean.
    询问修复机器人
  2. Shower Glass Silicone Replacement: 步骤 2 中的图像 1,3 Shower Glass Silicone Replacement: 步骤 2 中的图像 2,3 Shower Glass Silicone Replacement: 步骤 2 中的图像 3,3
    • Adjust the utility knife to a length of about 1 cm, or the width of the old silicone.
    • Cut at the top and bottom of the silicone (close to the glass and bathtub), all the way down to the end. Do not push past the adjusted knife length.
    询问修复机器人
  3. Shower Glass Silicone Replacement: 步骤 3 中的图像 1,3 Shower Glass Silicone Replacement: 步骤 3 中的图像 2,3 Shower Glass Silicone Replacement: 步骤 3 中的图像 3,3
    • Use a putty knife to separate the silicone from the bathtub and from the glass sides.
    • Pull the old silicone with your hand while using the putty knife to separate the silicone.
    询问修复机器人
  4. Shower Glass Silicone Replacement: 步骤 4 中的图像 1,3 Shower Glass Silicone Replacement: 步骤 4 中的图像 2,3 Shower Glass Silicone Replacement: 步骤 4 中的图像 3,3
    • Use a utility knife to remove any large sticking mold or silicone parts still left.
    • Use a fine grit sand paper to take off the small parts of the old silicone.
    • Vacuum away all the debris.
    • Be very precise and take your time with the knife.
    询问修复机器人
  5. Shower Glass Silicone Replacement: 步骤 5 中的图像 1,3 Shower Glass Silicone Replacement: 步骤 5 中的图像 2,3 Shower Glass Silicone Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    • Clean the area with a mold cleaner so that small matter, and particles can be removed. Spray the cleaner, wait about 15 minutes, scrub, and wash thoroughly until all the chemical is gone.
    • Wear gloves if using cleaner that has bleach or strong chemicals.
    • Now wipe the area clean with a microfiber cloth, until it is dry.
    询问修复机器人
  6. Shower Glass Silicone Replacement: 步骤 6 中的图像 1,3 Shower Glass Silicone Replacement: 步骤 6 中的图像 2,3 Shower Glass Silicone Replacement: 步骤 6 中的图像 3,3
    • Wait until the area is completely dry, which may also done by continuously wiping with a dry cloth.
    • Use painters tape to mask off both ends of the joint, at about a centimeter above and to the side of the tub.
    询问修复机器人
  7. Shower Glass Silicone Replacement: 步骤 7 中的图像 1,3 Shower Glass Silicone Replacement: 步骤 7 中的图像 2,3 Shower Glass Silicone Replacement: 步骤 7 中的图像 3,3
    • Place the new tube of silicone in the gun, and cut off about a half inch off of the tip. Poke the hole from the tip of the new silicone, with the accessory on the caulking gun.
    • Press slowly until the glue comes out slightly. Start from one end and press into the crack as you run the silicone to the other end in one motion. Use an amount of glue so that it comes out slightly at the corners that you're caulking.
    • Make sure to put enough glue and not too little, as you will need to run your finger down the glue in one motion to smooth it out. Run your finger only once.
    • Wait about 10 minutes and remove the tape, so that the glue doesn't fully dry with the tape. The finish will also look cleaner when you remove the tape after caulking.
    询问修复机器人
  8. Shower Glass Silicone Replacement: 步骤 8 中的图像 1,1
    • Let the area to completely dry for 24 hours before touching it or using the shower. The new silicone would be now mold free.
    询问修复机器人
结论
Make sure to be very careful with the glass and not damage with the knife. Using the knife always be cautious and safe, wearing gloves may help.
4等其他人完成本指南。
团队
York University, Team 1-32, O'Regan Fall 2021 York University, Team 1-32, O'Regan Fall 2021 的会员
YORK-O'REGAN-F21S1G32
1 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 47
过去 30 天: 275
总计 18,730
