跳转到主内容
Shop-Vac MC150A Power Switch Replacement
你所需要的
  1. Shop-Vac MC150A Power Switch Replacement, Unlatch the power unit assembly: 步骤 1 中的图像 1,1
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Power Switch Replacement, Remove the top cover: 步骤 2 中的图像 1,2 Shop-Vac MC150A Power Switch Replacement, Remove the top cover: 步骤 2 中的图像 2,2
    • Use a 3.5 mm hex key to remove the three screws securing the top cover.
    • Remove the top cover.
  3. Shop-Vac MC150A Power Switch Replacement: 步骤 3 中的图像 1,1
    • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
  4. Shop-Vac MC150A Power Switch Replacement: 步骤 4 中的图像 1,1
    • Separate the power unit assembly from the cover.
  5. Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: 步骤 5 中的图像 1,3 Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: 步骤 5 中的图像 2,3 Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: 步骤 5 中的图像 3,3
    • Pull out and disconnect the four spade connectors from the switch module.
    • During reassembly, use the last image as a reference for how to connect the wires.
  6. Shop-Vac MC150A Power Switch Replacement: 步骤 6 中的图像 1,1
    • Use a spudger to pry up and remove the red switch from the housing.
结论
6等其他人完成本指南。
Ngunlian
于02/08/16注册
732 声望
创作了5篇指南
团队
IUPUI, Team 1-2, Baechle Spring 2016 IUPUI, Team 1-2, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S1G2
5 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 146
总计 15,790
