跳转到主内容
Shop-Vac MC150A Filter Cage Replacement
你所需要的
  1. Shop-Vac MC150A Filter Cage Replacement, Unlatch the power unit assembly: 步骤 1 中的图像 1,1
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Filter Cage Replacement, Remove the foam sleeve: 步骤 2 中的图像 1,1
    • Slide the foam sleeve up from the filter cage to remove it.
  3. Shop-Vac MC150A Filter Cage Replacement, Unscrew the filter cage: 步骤 3 中的图像 1,1
    • Use a 3.5 mm hex key to remove the two screws securing the filter cage.
  4. Shop-Vac MC150A Filter Cage Replacement, Remove the filter cage: 步骤 4 中的图像 1,1
    • Remove the filter cage.
结论
Ngunlian
于02/08/16注册
732 声望
创作了5篇指南
团队
IUPUI, Team 1-2, Baechle Spring 2016 IUPUI, Team 1-2, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S1G2
5 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 38
总计 1,765
