跳转到主内容
Shimano Ultegra 6800 Caliper Brake Maintenance
你所需要的
  1. Shimano Ultegra 6800 Caliper Brake Maintenance, Shimano Ultegra 6800 Caliper Brake Maintenance: 步骤 1 中的图像 1,1
    • Using the 5mm allen wrench,check if the bolt on the backside of the caliper is snug.
  2. Shimano Ultegra 6800 Caliper Brake Maintenance: 步骤 2 中的图像 1,1
    • If your brake caliper is still tightened, loosen the cable bolt with a 5mm Allen wrench to take tension off the caliper.
  3. Shimano Ultegra 6800 Caliper Brake Maintenance: 步骤 3 中的图像 1,3 Shimano Ultegra 6800 Caliper Brake Maintenance: 步骤 3 中的图像 2,3 Shimano Ultegra 6800 Caliper Brake Maintenance: 步骤 3 中的图像 3,3
    • Check if the braking pads are contacting the rim in desired locations.
    • Both pads are loosened the same way.
    • For the left caliper pad, marked in the red circle, loosen the bolt with a 4mm Allen wrench so the pad can be adjusted.
    • Align the bottom edge of the pad with the bottom edge of the braking surface and then tighten.
    • For the right caliper pad, marked in the yellow circle, loosen the bolt with a 4mm Allen wrench so the pad can be adjusted.
    • Align the top edge of the pad with the top edge of the braking surface and then tighten.
  4. Shimano Ultegra 6800 Caliper Brake Maintenance: 步骤 4 中的图像 1,1
    • Check if your brake cable is inside the groove on the two plates (marked in the red cirlce) that hold the brake cable.
  5. Shimano Ultegra 6800 Caliper Brake Maintenance: 步骤 5 中的图像 1,2 Shimano Ultegra 6800 Caliper Brake Maintenance: 步骤 5 中的图像 2,2
    • If the adjustment lever is not turned down, turn it down.
  6. Shimano Ultegra 6800 Caliper Brake Maintenance: 步骤 6 中的图像 1,2 Shimano Ultegra 6800 Caliper Brake Maintenance: 步骤 6 中的图像 2,2
    • Squeeze the caliper until both sides are about 1mm from the rim.
    • While still squeezing, pull down the slack on the wire and tension the wire by bolting it down.
  7. Shimano Ultegra 6800 Caliper Brake Maintenance: 步骤 7 中的图像 1,1
    • Fine tune the brake calipers by using the barrel adjuster.
    • Counter clockwise turns open the calipers and clockwise turns close the calipers.
  8. Shimano Ultegra 6800 Caliper Brake Maintenance: 步骤 8 中的图像 1,1
    • Make the brake pads equidistant from the rim by adjusting the tiny bolt on top of the caliper with a 3mm Allen wrench.
  9. Shimano Ultegra 6800 Caliper Brake Maintenance: 步骤 9 中的图像 1,1
    • Check if the brakes are working properly by squeezing your brake levers.
结论
Check if your brakes are properly working before you ride. If the tightness and alignment are satisfactory, enjoy your ride.
7等其他人完成本指南。
Leland Lam
于02/24/15注册
348 声望
撰写一个指南
团队
Cal Poly, Team 24-4, Green Winter 2015 Cal Poly, Team 24-4, Green Winter 2015 的会员
CPSU-GREEN-W15S24G4
4 名成员
创作了3篇指南
5条评论
There is a second small adjusting screw further in on the caliper, pushing against the spring. I think I know what it’s for, but why not point that out, lest someone use it mistakenly. So?
David Kuch - 回复
What is the purpose of having the pads offset where one is lined up to the bottom of the rim and one lined up to the top as shown on Step #3 above in comparison to just having the pad surface completely the same?
spicedupflip - 回复
This is not needed on ultegra callipers as they are duel symmetric and both pads move up on braking. Pads should be set to the lower area of the rim. Duel pivot callipers need the above setting.
jeremy isaacs -
How do you make dual symmetric Ultegra calipers centred as they do not have the bolt in step 8?
Damon Murphy - 回复
Park tools has a great video on adjusting the calipers and addresses all types of calipers and explains how to adjust and center the pads.
https://www.youtube.com/watch?v=q4ay12CS...
lmi - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 142
总计 31,891
