跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Shift 5.1,请使用我们的维修手册
  1. Shift5.1 Teardown, Shift5.1 Teardown: 步骤 1 中的图像 1,3 Shift5.1 Teardown, Shift5.1 Teardown: 步骤 1 中的图像 2,3 Shift5.1 Teardown, Shift5.1 Teardown: 步骤 1 中的图像 3,3
    • The shift5.1 is the second biggest smartphone in the Shift series and features these specs:
    • 5-inch HD IPS display with a resolution of 1280x720 pixels (293,72 ppi)
    • Mediatek MT6582 Quadcore SoC with 1.3 GHz
    • 2GB DDR RAM + 16 GB internal memory
    • Dual sim (regular and micro sized)
    • 2000 mAh user-removable Li-Polymer battery
    • 5 MP front and 8 MP rear camera
    • Android​ 5.1 Lollipop
  2. Shift5.1 Teardown: 步骤 2 中的图像 1,2 Shift5.1 Teardown: 步骤 2 中的图像 2,2
    • The shift5.1 measures in at 144 x 72 x 7 mm and weighs 140 grams.
    • This makes it about the same size as the Fairphone 2. But a lot thinner.
    • For those who did not already know—it holds a small warning on its rear case:
    • smartphones can be timekillers. there is no greater gift for you today, than the next 24hours. use them wisely. people are more important than machines.
  3. Shift5.1 Teardown: 步骤 3 中的图像 1,2 Shift5.1 Teardown: 步骤 3 中的图像 2,2
    • Having a user-removable battery usually equates to an easily removed back cover.
    • And that's what it is: very easy. We start with a small notch at the lower end of the cover and the flexible black plastic gives way to reveal the battery.
  4. Shift5.1 Teardown: 步骤 4 中的图像 1,2 Shift5.1 Teardown: 步骤 4 中的图像 2,2
    • Taking the battery out is also easy as pie.
    • The 2000 mAh brings you 7.6 Wh at 3.8V, settling behind the 9.2 Wh from the Fairphone 2 battery.
  5. Shift5.1 Teardown: 步骤 5 中的图像 1,3 Shift5.1 Teardown: 步骤 5 中的图像 2,3 Shift5.1 Teardown: 步骤 5 中的图像 3,3
    • We bring out the Phillips #000 to loosen the seven screws and get further into the shift5.1.
    • A plastic opening tool helps us prying away the plastic frame.
  6. Shift5.1 Teardown: 步骤 6 中的图像 1,2 Shift5.1 Teardown: 步骤 6 中的图像 2,2
    • Before we take the frame aside we take a short look at the loudspeaker which is embedded with a mild double sided adhesive tape.
  7. Shift5.1 Teardown: 步骤 7 中的图像 1,3 Shift5.1 Teardown: 步骤 7 中的图像 2,3 Shift5.1 Teardown: 步骤 7 中的图像 3,3
    • On the back of the display unit we see the motherboard with a multitude of components mounted on it.
    • We unplug both of the display connectors and peel the volume buttons and power button unit loose from the frame.
    • A single Phillips screw holds the motherboard in place.
  8. Shift5.1 Teardown: 步骤 8 中的图像 1,3 Shift5.1 Teardown: 步骤 8 中的图像 2,3 Shift5.1 Teardown: 步骤 8 中的图像 3,3
    • Now we can careful lift up the motherboard and take away the 8 MP rear camera.
  9. Shift5.1 Teardown: 步骤 9 中的图像 1,3 Shift5.1 Teardown: 步骤 9 中的图像 2,3 Shift5.1 Teardown: 步骤 9 中的图像 3,3
    • In regular teardown fashion, we get to work peeling up the strongly-adhered plastic cover in the base of the battery housing.
    • This huge black adhesive plastic foil hides the interconnect cable running from the motherboard to the daughterboard.
    • Breaking up adhesive is usually a destructive process, and this means that a simple daughterboard may become complicated quickly.
    • There is also a little adhesive tape over the daughterboard.
  10. Shift5.1 Teardown: 步骤 10 中的图像 1,3 Shift5.1 Teardown: 步骤 10 中的图像 2,3 Shift5.1 Teardown: 步骤 10 中的图像 3,3
    • After lifting the vibrator and the microphone carefully out of their recesses we free the daughterboard by loosening two more Phillips screws.
  11. Shift5.1 Teardown: 步骤 11 中的图像 1,1
    • And here we have the heart of the shift5.1:
    • Mediatek MT6582 SoC with an ARM Cortex A7
    • Samsung KMR820001M-B609 2GB LPDDR2 memory
    • Mediatek MT6627 Diplexer QVL for WIFI/BT/GPS
    • Mediatek MT6166V RF transceiver
    • Mediatek MT6323GA PMIC
    • AIROHA AP6684 quad-band GPRS front-end module
  12. Shift5.1 Teardown: 步骤 12 中的图像 1,1
    • On the flip side we're met with an unfortunate surprise:
    • All the remaining components are soldered to the motherboard, including the front facing camera, headphone jack and the power and volume buttons.
    • While taking a soldering iron to these connections isn't impossible, unskilled users would have trouble replacing these components without damaging their hardware.
  13. Shift5.1 Teardown: 步骤 13 中的图像 1,3 Shift5.1 Teardown: 步骤 13 中的图像 2,3 Shift5.1 Teardown: 步骤 13 中的图像 3,3
    • Last but not least we have the remaining display which carries the earpiece speaker.
    • Taking it out leaves us with the fused display which carries a GOODiX GT9147 touch screen controller on the flex cable.
  14. Shift5.1 Teardown: 步骤 14 中的图像 1,1
    • And here we have the shift5.1 spread out on the teardown table showing us all it has to offer.
  15. 最后的想法
    • Cover and battery are easy to remove and can be swapped without using tools.
    • No excessive glue and no proprietary screws are used, only Phillips #000.
    • Shift offers a forum and a youtube channel with some information and tutorials (unfortunately only in German).
    • The fused display can be changed but you need to take out everything else reminding us of the iPhone 4 and 4s.
    • Lots of components and connectors are soldered to the motherboard. They could be soldered by hand if needed but this makes repairs more difficult.
    可修复性评分
    6
    可修复性10分中得6分
    (10是最容易修复)
Tobias Isakeit
于03/31/14注册
117,296 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,521篇指南
6条评论
the display can be changed in 2 ways:
either with the a-frame or without. if changing only display without a-frame, you only need to open 2 connectors and take of the display and stick the new one on with the sticker-set, that comes with the display. this way you do not need to take out the electronics and you will be done much faster ;-).
cwaldeck - 回复
by the way:
You can get any SHIFT spare part you want and need at: support@shiftphones.com
cwaldeck - 回复
I do not unterstand why it have only a 6 I woud take it between 8 and 9
Sven Ulrich - 回复
Only a handful of components aren’t soldered and you have to take a lot apart to change common parts like the display. I understand why it’s not a 8 or 9 but a fully agree I don’t understand why it’s a 6 and not e.g. a 5 or 7. Is there any comparison what has to exist to justify a specific grade?
LastDawn -
jup. we also think a 7 would have been fair.
i think the problem was that the iFixit team took the complicated repair-way. if they followed the instructions from SHIFT for sure it would have been a 7 score. but anyway… this is now long time ago :-)…
cwaldeck -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 18
总计 6,393
