跳转到主内容
Shenzhou k680e Silicone Grease Replacement
你所需要的
  1. Shenzhou k680e Silicone Grease Replacement, Silicone Grease: 步骤 1 中的图像 1,1
    • Place the computer on a table so that its bottom surface is facing you.
  2. Shenzhou k680e Silicone Grease Replacement: 步骤 2 中的图像 1,1
    • Remove all the screws on the bottom with a screwdriver.
  3. Shenzhou k680e Silicone Grease Replacement: 步骤 3 中的图像 1,1
    • Slide the battery upwards to remove it from the laptop.
  4. Shenzhou k680e Silicone Grease Replacement: 步骤 4 中的图像 1,1
    • Pry the back panel away from the laptop using an opening tool.
  5. Shenzhou k680e Silicone Grease Replacement: 步骤 5 中的图像 1,1
    • Remove the screws from the fan.
    • Detach the fan's wire from the motherboard.
  6. Shenzhou k680e Silicone Grease Replacement: 步骤 6 中的图像 1,1
    • Remove the fans from the laptop.
  7. Shenzhou k680e Silicone Grease Replacement: 步骤 7 中的图像 1,1
    • Use a brush or an electric fan to clean the dust on the fans.
    • Don't use your finger to clean it because it may cause permanent damage to the fan.
  8. Shenzhou k680e Silicone Grease Replacement: 步骤 8 中的图像 1,1
    • Remove the screws from the CPU in the following order according to the index numbers beside the screws: 3, 2, 1.
    • When you reinstall these screws you should follow the order: 1, 2, 3.
  9. Shenzhou k680e Silicone Grease Replacement: 步骤 9 中的图像 1,2 Shenzhou k680e Silicone Grease Replacement: 步骤 9 中的图像 2,2
    • Remove the heat sink from the laptop.
    • There is some old thermal paste on the copper section of the heat sink.
  10. Shenzhou k680e Silicone Grease Replacement: 步骤 10 中的图像 1,1
    • Use an alcohol wipe to clean the thermal paste on the copper sheet.
    • You must use an alcohol wipe since alcohol is volatile and will not stay inside the computer, unlike water.
  11. Shenzhou k680e Silicone Grease Replacement: 步骤 11 中的图像 1,1
    • Squeeze new thermal paste onto the chips.
结论
另外一个人完成了本指南。
Yizhen Qu
于09/20/20注册
217 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 667
