跳转到主内容
Sharper Image iPulse SI325 Outer Case Replacement
你所需要的
  1. Sharper Image iPulse SI325 Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,2 Sharper Image iPulse SI325 Outer Case Replacement, Outer Case: 步骤 1 中的图像 2,2
    • Gently position the device so that the buttons and speakers lie face down.
    • Unplug the power cord from the "DC Input."
  2. Sharper Image iPulse SI325 Outer Case Replacement: 步骤 2 中的图像 1,3 Sharper Image iPulse SI325 Outer Case Replacement: 步骤 2 中的图像 2,3 Sharper Image iPulse SI325 Outer Case Replacement: 步骤 2 中的图像 3,3
    • Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
    • Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together.
    • Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
    • With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
    • A small gap will open as the two tabs are released.
    • Do not pull the two halves apart yet. They are held together by the speaker wire.
  3. Sharper Image iPulse SI325 Outer Case Replacement: 步骤 3 中的图像 1,2 Sharper Image iPulse SI325 Outer Case Replacement: 步骤 3 中的图像 2,2
    • Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
    • Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
    • Lay the device down, so that all the internal components are facing upwards.
结论
Melissa Pasa
于10/13/13注册
701 声望
创作了7篇指南
团队
Cal Poly, Team 11-33, Amido Fall 2013 Cal Poly, Team 11-33, Amido Fall 2013 的会员
CPSU-AMIDO-F13S11G33
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 342
