跳转到主内容
Sharp-EL-531xg Battery Replacement
你所需要的
  1. Sharp-EL-531xg Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Press the 2nd F button and then the OFF button to power down the calculator.
  2. Sharp-EL-531xg Battery Replacement: 步骤 2 中的图像 1,2 Sharp-EL-531xg Battery Replacement: 步骤 2 中的图像 2,2
    • Flip the calculator over so the back is facing upwards.
    • Remove the single screw from the battery panel using a Phillips #0 screwdriver.
  3. Sharp-EL-531xg Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the battery cover using two fingers.
  4. Sharp-EL-531xg Battery Replacement: 步骤 4 中的图像 1,3 Sharp-EL-531xg Battery Replacement: 步骤 4 中的图像 2,3 Sharp-EL-531xg Battery Replacement: 步骤 4 中的图像 3,3
    • Place a spudger in the slot next to the battery and pry upwards to remove the battery.
    • Avoid using a sharp tool to remove the battery.
  5. Sharp-EL-531xg Battery Replacement: 步骤 5 中的图像 1,1
    • Place the new battery into the slot with the positive (+) side facing upwards
    • Don't press the battery too hard.
  6. Sharp-EL-531xg Battery Replacement: 步骤 6 中的图像 1,1
    • Put the battery cover back on.
    • Tighten the battery cover screw with a Phillips #0 screwdriver.
  7. Sharp-EL-531xg Battery Replacement: 步骤 7 中的图像 1,2 Sharp-EL-531xg Battery Replacement: 步骤 7 中的图像 2,2
    • Press the On button to turn on the calculator.
    • Flip the calculator over so the bottom is facing upwards.
    • Press the reset button with the pointed end of a spudger to restart the calculator.
终点
另外一个人完成了本指南。
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 30
总计 780
