跳转到主内容
Sharp PC-MM20 Keyboard Replacement
你所需要的
  1. Sharp PC-MM20 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • First, make sure the laptop is powered down. Then, remove the battery from the laptop.
  2. Sharp PC-MM20 Keyboard Replacement: 步骤 2 中的图像 1,2 Sharp PC-MM20 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Close the laptop.
    • Turn the laptop so that the back is facing you.
    • There will be three screws on the back. Remove each screw by using the screw driver.
    • Keep the three screws in a safe place. A magnetic pad is an example of a safe place.
  3. Sharp PC-MM20 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Next, flip the laptop so that you can see the bottom.
    • Remove the screws shown in the picture.
  4. Sharp PC-MM20 Keyboard Replacement: 步骤 4 中的图像 1,2 Sharp PC-MM20 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Next, open the laptop and focus on the front of the base of the laptop.
    • Notice that there are small notches in between the two plates of the laptop. There are several slots such as this that are found across the front base of the laptop.
    • Take a flat edge and wedge it into the slot to pop it open.
  5. Sharp PC-MM20 Keyboard Replacement: 步骤 5 中的图像 1,2 Sharp PC-MM20 Keyboard Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Once the cover is loose, it should be able to shift somewhat freely. However, there are a few more connections holding it together.
    • Next, use tweezers to delicately remove the flat cable that connects the keyboard to the laptop.
    • Then, remove the flat cable from the track pad of the laptop.
  6. Sharp PC-MM20 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Now that all the connections are removed, remove the top of the base from the rest of the computer.
  7. Sharp PC-MM20 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Lastly, take the old keyboard out of the base and replace it with the new keyboard.
结论
2等其他人完成本指南。
Logan Lindsey
于09/11/13注册
128 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 758
