简介
This guide will show you how to replace the door switch for the Sharp Microwave so that it will not turn on when the door is opened.
你所需要的
Sharp microwave running with door open
Problem with the hardware interlock switches triggered by the door latch
Sharp model R-248BS
Side screw
...and 4 screws in the back
Star screws need T15X4 or equivalent. A flathead can be used in a pinch.
Remove the screws
Remove the case, should slide out with a little bit of effort.due to notches in the frame on the front top left ( when looking from the back).
Now we will identify the switches
The lower two switches
... and the upper switch
Upper switch faulty
Top switch appears loose
Replace and reinstall
Angled reinsertion to line up hole with plastic support
