跳转到主内容
Sharp LC-42D62U T-Con Board Replacement
你所需要的
  1. Sharp LC-42D62U  T-Con Board Replacement, Remove the SD card cover: 步骤 1 中的图像 1,1
    • To replace the T-Con board it is not necessary to remove the base.
    • Lay the the TV flat on a padded surface.
  2. Sharp LC-42D62U  T-Con Board Replacement, Detach the rear cover: 步骤 2 中的图像 1,1
    • Remove 17 screws.
  3. Sharp LC-42D62U  T-Con Board Replacement, Remove the stand fixing angle: 步骤 3 中的图像 1,1
    • To reassemble all the parts easily, mark with a permanent marker the location of the screws you are removing.
    • 4 screws hold the nd fixing angle.
  4. Sharp LC-42D62U  T-Con Board Replacement, Remove left and right center angles: 步骤 4 中的图像 1,1
    • 2 screws hold each center angles.
  5. Sharp LC-42D62U  T-Con Board Replacement, Remove the main shield: 步骤 5 中的图像 1,1
    • 9 screws.
  6. Sharp LC-42D62U  T-Con Board Replacement, Disconnect connectors: 步骤 6 中的图像 1,1
    • Insert wisdom here.
  7. Sharp LC-42D62U  T-Con Board Replacement, Remove the tray chassis: 步骤 7 中的图像 1,1
    • 7 screws.
  8. Sharp LC-42D62U  T-Con Board Replacement, Remove the tray fixing angles and the lug angle top: 步骤 8 中的图像 1,1
    • Remove the 7 screws holding the lug angle top.
    • Then remove only the bottom screws from the tray fixing angles, leaving the top screws attached to the lug angle top.
  9. Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board shield: 步骤 9 中的图像 1,2 Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board shield: 步骤 9 中的图像 2,2
    • 5 screws.
  10. Sharp LC-42D62U  T-Con Board Replacement, Remove the last screw and disconnect the 4 ribbon cables: 步骤 10 中的图像 1,1
    • To disconnect the ribbon cables, lift the brown tab on the connector.
    • Make sure the ribbons are positioned correctly in the connector when reassembling the new board.
  11. Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board: 步骤 11 中的图像 1,2 Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board: 步骤 11 中的图像 2,2
    • There are two pads glued under the board (see yellow marks in the picture): use a heat gun to soften them and then gently pry them to detach the board from the frame.
    • There are also 4 tabs holding the board: gently pull the board to release it, after the pads are disconnected.
    • Reposition the pads on the chassis before installing the new board.
结论
另外一个人完成了本指南。
Emme
于06/15/17注册
903 声望
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 51
总计 1,419
