跳转到主内容
加入维修社区 - 创建账户
Sharp EL-W535XG Battery Replacement
你所需要的
  1. Sharp EL-W535XG Battery Replacement, Battery: 步骤 1 中的图像 1,2 Sharp EL-W535XG Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off the calculator by pressing both the [2NDF ] and [ON] buttons at the same time.
  2. Sharp EL-W535XG Battery Replacement: 步骤 2 中的图像 1,1
    • Flip the calculator so that the battery cover is facing you, and it will be easy to remove.
  3. Sharp EL-W535XG Battery Replacement: 步骤 3 中的图像 1,2 Sharp EL-W535XG Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the two screws securing the battery cover with the Tri-point #000 screwdriver.
    • Remove the battery cover.
    • Make sure not to remove the other screws on the calculator, just the two screws on the battery cover.
  4. Sharp EL-W535XG Battery Replacement: 步骤 4 中的图像 1,2 Sharp EL-W535XG Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the worn-out LR44 battery inside using a spudger.
  5. Sharp EL-W535XG Battery Replacement: 步骤 5 中的图像 1,1
    • Gently insert the new LR44 battery in the empty battery slot.
  6. Sharp EL-W535XG Battery Replacement: 步骤 6 中的图像 1,1
    • Place and screw the battery cover on using the Tri-point #000 screwdriver.
    • Tightly screw the battery cover to prevent losing screws.
结论
Faduma Hagi
于09/14/21注册
133 声望
撰写一个指南
团队
York University, Team 1-7, O'Regan Fall 2021 York University, Team 1-7, O'Regan Fall 2021 的会员
YORK-O'REGAN-F21S1G7
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 39
总计 2,274
