跳转到主内容
Sharp EL-520X Loose Circuit Board Wire Fix
你所需要的
  1. Sharp EL-520X Loose Circuit Board Wire Fix, Sharp EL-520X Loose Circuit Board Wire Fix: 步骤 1 中的图像 1,1
    • Remove the single screw from the battery door using a Phillips #00 screwdriver.
    • Remove the battery door.
  2. Sharp EL-520X Loose Circuit Board Wire Fix: 步骤 2 中的图像 1,2 Sharp EL-520X Loose Circuit Board Wire Fix: 步骤 2 中的图像 2,2
    • Remove two screws inside the battery compartment using a Phillips #00 screwdriver.
    • Remove the four screws in the corners of the calculator using a Phillips #00 screwdriver.
  3. Sharp EL-520X Loose Circuit Board Wire Fix: 步骤 3 中的图像 1,1
    • Flip the calculator to the front panel and use an opening pick to pry around the sides of the panel to pop it open.
    • Gently lay it open to reveal the circuit board inside.
  4. Sharp EL-520X Loose Circuit Board Wire Fix: 步骤 4 中的图像 1,1
    • Using a de-soldering braid, remove the old solder on the area where the loose solar cell wire will be fixed to.
    • Be careful not to damage your circuit board with the hot soldering iron. Do not place the soldering iron tip near the circuit board for long periods of time.
    • Use a soldering iron rest, so you don't directly place the hot soldering iron on your working surfaces which may lead to damages.
  5. Sharp EL-520X Loose Circuit Board Wire Fix: 步骤 5 中的图像 1,1
    • Place the loose solar cell wire on to the de-soldered area of the circuit board and apply new solder on to that area.
  6. Sharp EL-520X Loose Circuit Board Wire Fix: 步骤 6 中的图像 1,1
    • Carefully place the back panel back on to the calculator.
  7. Sharp EL-520X Loose Circuit Board Wire Fix: 步骤 7 中的图像 1,3 Sharp EL-520X Loose Circuit Board Wire Fix: 步骤 7 中的图像 2,3 Sharp EL-520X Loose Circuit Board Wire Fix: 步骤 7 中的图像 3,3
    • Secure the back panel with the screws you removed in Steps 1 and 2 using a Phillips #00 screwdriver.
终点
2等其他人完成本指南。
Mohamad Mohamad
于01/18/21注册
436 声望
创作了3篇指南
团队
York University, Team M-6, Allen Summer 2023 York University, Team M-6, Allen Summer 2023 的会员
YORK-ALLEN-SU23SMG6
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 28
总计 282
