跳转到主内容
加入维修社区 - 创建账户
Sharp EL-510RN Battery Replacement
你所需要的
  1. Sharp EL-510RN Battery Replacement, Battery: 步骤 1 中的图像 1,2 Sharp EL-510RN Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Find a clean workspace free of clutter.
    • Cover the calculator with the gray screen it came with. This will prevent any buttons from being pressed when it's flipped over.
  2. Sharp EL-510RN Battery Replacement: 步骤 2 中的图像 1,3 Sharp EL-510RN Battery Replacement: 步骤 2 中的图像 2,3 Sharp EL-510RN Battery Replacement: 步骤 2 中的图像 3,3
    • Flip the calculator over so the backside is facing up.
    • Use a Phillips #0 screwdriver to remove the screw securing the battery cover.
    • Use a spudger to pry open the battery cover.
  3. Sharp EL-510RN Battery Replacement: 步骤 3 中的图像 1,3 Sharp EL-510RN Battery Replacement: 步骤 3 中的图像 2,3 Sharp EL-510RN Battery Replacement: 步骤 3 中的图像 3,3
    • Use a spudger to pry the battery out of the back of the calculator.
    • Always use an ESD safe tool when working with batteries or delicate components such as the motherboard.
  4. Sharp EL-510RN Battery Replacement: 步骤 4 中的图像 1,3 Sharp EL-510RN Battery Replacement: 步骤 4 中的图像 2,3 Sharp EL-510RN Battery Replacement: 步骤 4 中的图像 3,3
    • Insert the new battery into the socket.
    • Put the panel back on and screw it into place.
  5. Sharp EL-510RN Battery Replacement: 步骤 5 中的图像 1,1
    • Congratulations you've now successfully completed a battery replacement on the Sharp EL-510RN!
结论
Harish Kugathasalingam
于10/21/22注册
121 声望
撰写一个指南
团队
York University, Team 4-5, Allen Fall 2022 York University, Team 4-5, Allen Fall 2022 的会员
YORK-ALLEN-F22S4G5
2 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 45
总计 1,234
