当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
Remove the two speaker cables from the circuit board by pinching the plastic connectors and firmly pulling up.
Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
Do not remove the speakers yet—they are still attached.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
