跳转到主内容
Sharp Aquos LC13B2UA Power Button Replacement
你所需要的
  1. Sharp Aquos LC13B2UA Power Button Replacement, Stand: 步骤 1 中的图像 1,2 Sharp Aquos LC13B2UA Power Button Replacement, Stand: 步骤 1 中的图像 2,2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Power Button Replacement: 步骤 2 中的图像 1,2 Sharp Aquos LC13B2UA Power Button Replacement: 步骤 2 中的图像 2,2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Power Button Replacement, Back Case: 步骤 3 中的图像 1,3 Sharp Aquos LC13B2UA Power Button Replacement, Back Case: 步骤 3 中的图像 2,3 Sharp Aquos LC13B2UA Power Button Replacement, Back Case: 步骤 3 中的图像 3,3
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Power Button Replacement: 步骤 4 中的图像 1,2 Sharp Aquos LC13B2UA Power Button Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Power Button Replacement: 步骤 5 中的图像 1,1
    • Using your hands, gently lift and remove the back case of the television.
  6. Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: 步骤 6 中的图像 1,3 Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: 步骤 6 中的图像 2,3 Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  7. Sharp Aquos LC13B2UA Power Button Replacement: 步骤 7 中的图像 1,2 Sharp Aquos LC13B2UA Power Button Replacement: 步骤 7 中的图像 2,2
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  8. Sharp Aquos LC13B2UA Power Button Replacement: 步骤 8 中的图像 1,2 Sharp Aquos LC13B2UA Power Button Replacement: 步骤 8 中的图像 2,2
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  9. Sharp Aquos LC13B2UA Power Button Replacement: 步骤 9 中的图像 1,1
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
  10. Sharp Aquos LC13B2UA Power Button Replacement, Power Button: 步骤 10 中的图像 1,3 Sharp Aquos LC13B2UA Power Button Replacement, Power Button: 步骤 10 中的图像 2,3 Sharp Aquos LC13B2UA Power Button Replacement, Power Button: 步骤 10 中的图像 3,3
    • Remove the two 6mm Phillips screws.
    • Pull the board toward you, giving you access to the power button.
结论
Robert Hobson
于01/20/11注册
1,290 声望
创作了9篇指南
团队
Cal Poly, Team 1-11, Amido Winter 2011 Cal Poly, Team 1-11, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G11
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 60
总计 7,109
