当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
Turn the circuit board so the blue and pink side cables are facing you.
Hold the white plastic, squeeze and pull from the sides.
Turn the television so the right hand side is facing you.
To remove the ribbon cables, fold the brown casing down and pull directly upward on the ribbon.
Turn the television so the left hand side is facing you, and remove the ribbon cable in the same manner.
Turn the circuit board so that the left side is facing you.
Detach the data cable from the circuit board.
To do this, slide your finger nail from the middle of the connector until the little black tabs rotates down toward the board as shown in the second picture.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
