跳转到主内容
Sharp Aquos LC13B2UA LCD Replacement
你所需要的
  1. Sharp Aquos LC13B2UA LCD Replacement, Stand: 步骤 1 中的图像 1,2 Sharp Aquos LC13B2UA LCD Replacement, Stand: 步骤 1 中的图像 2,2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA LCD Replacement: 步骤 2 中的图像 1,2 Sharp Aquos LC13B2UA LCD Replacement: 步骤 2 中的图像 2,2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA LCD Replacement, Back Case: 步骤 3 中的图像 1,3 Sharp Aquos LC13B2UA LCD Replacement, Back Case: 步骤 3 中的图像 2,3 Sharp Aquos LC13B2UA LCD Replacement, Back Case: 步骤 3 中的图像 3,3
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA LCD Replacement: 步骤 4 中的图像 1,2 Sharp Aquos LC13B2UA LCD Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA LCD Replacement: 步骤 5 中的图像 1,1
    • Using your hands, gently lift and remove the back case of the television.
  6. Sharp Aquos LC13B2UA LCD Replacement, Motherboard: 步骤 6 中的图像 1,3 Sharp Aquos LC13B2UA LCD Replacement, Motherboard: 步骤 6 中的图像 2,3 Sharp Aquos LC13B2UA LCD Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  7. Sharp Aquos LC13B2UA LCD Replacement: 步骤 7 中的图像 1,2 Sharp Aquos LC13B2UA LCD Replacement: 步骤 7 中的图像 2,2
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  8. Sharp Aquos LC13B2UA LCD Replacement: 步骤 8 中的图像 1,2 Sharp Aquos LC13B2UA LCD Replacement: 步骤 8 中的图像 2,2
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  9. Sharp Aquos LC13B2UA LCD Replacement: 步骤 9 中的图像 1,1
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
  10. Sharp Aquos LC13B2UA LCD Replacement, LCD: 步骤 10 中的图像 1,1
    • Flip the LCD/circuit board so that the circuit board faces up.
  11. Sharp Aquos LC13B2UA LCD Replacement: 步骤 11 中的图像 1,3 Sharp Aquos LC13B2UA LCD Replacement: 步骤 11 中的图像 2,3 Sharp Aquos LC13B2UA LCD Replacement: 步骤 11 中的图像 3,3
    • Remove the three 5mm Philips screws attaching the circuit board to the LCD.
    • Remove the five 6mm Phillips screws from the edges of the circuit board attacking it to the LCD.
  12. Sharp Aquos LC13B2UA LCD Replacement: 步骤 12 中的图像 1,3 Sharp Aquos LC13B2UA LCD Replacement: 步骤 12 中的图像 2,3 Sharp Aquos LC13B2UA LCD Replacement: 步骤 12 中的图像 3,3
    • Turn the circuit board so the blue and pink side cables are facing you.
    • Hold the white plastic, squeeze and pull from the sides.
  13. Sharp Aquos LC13B2UA LCD Replacement: 步骤 13 中的图像 1,3 Sharp Aquos LC13B2UA LCD Replacement: 步骤 13 中的图像 2,3 Sharp Aquos LC13B2UA LCD Replacement: 步骤 13 中的图像 3,3
    • Turn the television so the right hand side is facing you.
    • To remove the ribbon cables, fold the brown casing down and pull directly upward on the ribbon.
    • Turn the television so the left hand side is facing you, and remove the ribbon cable in the same manner.
  14. Sharp Aquos LC13B2UA LCD Replacement: 步骤 14 中的图像 1,3 Sharp Aquos LC13B2UA LCD Replacement: 步骤 14 中的图像 2,3 Sharp Aquos LC13B2UA LCD Replacement: 步骤 14 中的图像 3,3
    • Turn the circuit board so that the left side is facing you.
    • Detach the data cable from the circuit board.
    • To do this, slide your finger nail from the middle of the connector until the little black tabs rotates down toward the board as shown in the second picture.
  15. Sharp Aquos LC13B2UA LCD Replacement: 步骤 15 中的图像 1,1
    • Lift and remove the circuit board from the LCD frame.
  16. Sharp Aquos LC13B2UA LCD Replacement: 步骤 16 中的图像 1,1
    • Now you have your LCD.
结论
2等其他人完成本指南。
Robert Hobson
于01/20/11注册
1,290 声望
创作了9篇指南
团队
Cal Poly, Team 1-11, Amido Winter 2011 Cal Poly, Team 1-11, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G11
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 8,661
