跳转到主内容
简介
Outline what you are going to teach someone how to do.
配件
没有特定配件。
  1. Place the TV face down on a flat smooth surface as to not scratch the screen. Remove the four 8mm screws attaching the stand to the TV.
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Remove the four 8mm screws attaching the stand to the TV.
  2. Lift the stand off the television. Lift the stand off the television.
    • Lift the stand off the television.
  3. Remove the two back panels. Remove the two back panels. Remove the two back panels.
    • Remove the two back panels.
  4. Remove the eight 6mm Phillips screws around the edge. Remove the two 6mm Phillips screws near the inputs.
    • Remove the eight 6mm Phillips screws around the edge.
    • Remove the two 6mm Phillips screws near the inputs.
  5. Lift and remove the back case of the television.
    • Lift and remove the back case of the television.
  6. PC 笔记本电池
    An easy fix for a big power boost.
    现在开始购物
    PC 笔记本电池
    现在开始购物
  7. Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up. Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires. Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  8. Remove the green and gray power connector from the side of the buttons panel at the top of the television. Remove the green/gray to orange/gray connector from the center of the circuit board.
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  9. Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case. Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  10. Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
  11. Remove the two 6mm Phillips screws. Pull the board toward you, giving you access to the power button. Pull the board toward you, giving you access to the power button.
    • Remove the two 6mm Phillips screws.
    • Pull the board toward you, giving you access to the power button.
  12. Unscrew the two 4mm Phillips screws. Lift the buttons off the front case.
    • Unscrew the two 4mm Phillips screws.
    • Lift the buttons off the front case.
  13. Remove the eight 10mm screws connecting the two speakers to the front case. Remove the eight 10mm screws connecting the two speakers to the front case.
    • Remove the eight 10mm screws connecting the two speakers to the front case.
  14. Remove the two black tape strips securing the audio cables to the case. Lift the audio cable from the plastic prongs securing it to the front case The speakers can now be removed.
    • Remove the two black tape strips securing the audio cables to the case.
    • Lift the audio cable from the plastic prongs securing it to the front case
    • The speakers can now be removed.
  15. To remove the LED circuit at the base of the front casing, unscrew the two 5mm Phillips screws. Lift the circuit to remove the plastic LED casing. Lift the circuit to remove the plastic LED casing.
    • To remove the LED circuit at the base of the front casing, unscrew the two 5mm Phillips screws.
    • Lift the circuit to remove the plastic LED casing.
结论
另外一个人完成了本指南。
Robert Hobson
于2011年01月20日注册
1,275 信誉积分
创作了9篇指南
团队
Cal Poly, Team 1-11, Amido Winter 2011 Cal Poly, Team 1-11, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G11
4 名成员
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 6
总计 2,577
