当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Place the TV face down on a flat smooth surface as to not scratch the screen.
Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
Lift the stand off the television.
Remove the two back panels by prying them out with your hands.
Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
Using your hands, gently lift and remove the back case of the television.
取消:我没有完成这个指南。
与7其他贡献者
于01/20/11注册
1,290 声望
创作了9篇指南
徽章: 12
+ 9更多徽章
CPSU-AMIDO-W11S1G11
4 名成员
How do you remove the casing of a sharp LC26SB25E ? Please.
alan - 2017年9月6日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 14
总计 4,111
