跳转到主内容
Sharp Aquos Crystal Motherboard Replacement
你所需要的
  1. Sharp Aquos Crystal Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,3 Sharp Aquos Crystal Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,3 Sharp Aquos Crystal Motherboard Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
  2. Sharp Aquos Crystal Motherboard Replacement, USB Port: 步骤 2 中的图像 1,2 Sharp Aquos Crystal Motherboard Replacement, USB Port: 步骤 2 中的图像 2,2
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
  3. Sharp Aquos Crystal Motherboard Replacement: 步骤 3 中的图像 1,2 Sharp Aquos Crystal Motherboard Replacement: 步骤 3 中的图像 2,2
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
  4. Sharp Aquos Crystal Motherboard Replacement: 步骤 4 中的图像 1,2 Sharp Aquos Crystal Motherboard Replacement: 步骤 4 中的图像 2,2
    • Disconnect the wire by lifting it up with a plastic opening tool.
  5. Sharp Aquos Crystal Motherboard Replacement: 步骤 5 中的图像 1,3 Sharp Aquos Crystal Motherboard Replacement: 步骤 5 中的图像 2,3 Sharp Aquos Crystal Motherboard Replacement: 步骤 5 中的图像 3,3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  6. Sharp Aquos Crystal Motherboard Replacement: 步骤 6 中的图像 1,1
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
  7. Sharp Aquos Crystal Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Peel off the black pieces of tape.
  8. Sharp Aquos Crystal Motherboard Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
  9. Sharp Aquos Crystal Motherboard Replacement: 步骤 9 中的图像 1,2 Sharp Aquos Crystal Motherboard Replacement: 步骤 9 中的图像 2,2
    • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
  10. Sharp Aquos Crystal Motherboard Replacement: 步骤 10 中的图像 1,1
    • Peel the tape off with your hands.
  11. Sharp Aquos Crystal Motherboard Replacement: 步骤 11 中的图像 1,1
    • Lift the motherboard out with your hands.
结论
另外一个人完成了本指南。
Felicia Imbriano
于03/08/16注册
1,169 声望
创作了8篇指南
团队
UMass Dartmouth, Team 7-4, Catania Spring 2016 UMass Dartmouth, Team 7-4, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S7G4
3 名成员
创作了24篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 34
总计 2,375
