跳转到主内容
Shark Vertex Pro IZ682H Post-Motor Filter Replacement
你所需要的
  1. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Battery: 步骤 1 中的图像 1,1
    • On the bottom of the device handle, you will find a button on the left side. Press and hold this button.
  2. Shark Vertex Pro IZ682H Post-Motor Filter Replacement: 步骤 2 中的图像 1,1
    • While holding the button, slide the battery out of the device.
    • If the battery needs replacing, you can find one on the Shark website.
  3. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Pre-Motor Filter: 步骤 3 中的图像 1,2 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Pre-Motor Filter: 步骤 3 中的图像 2,2
    • On the body of the device you will find there is a large grey button on the side of the dust cup.
    • Pressing this button will release the dust cup from the body of the device.
    • Empty the dust cup if the device has already been in use.
  4. Shark Vertex Pro IZ682H Post-Motor Filter Replacement: 步骤 4 中的图像 1,2 Shark Vertex Pro IZ682H Post-Motor Filter Replacement: 步骤 4 中的图像 2,2
    • Under the dust cup you will find that there is a white pre-motor filter. Remove this filter.
  5. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: 步骤 5 中的图像 1,3 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: 步骤 5 中的图像 2,3 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: 步骤 5 中的图像 3,3
    • You will find the post-motor filter in the device under where the dust cup was.
    • The post-motor filter can be easily removed now.
    • Clean the filter with soap and water.
    • Examine your filter for any damage, and if you find any you can buy a replacement on the Shark website.
结论
Tyree Brooks
于10/26/22注册
486 声望
创作了5篇指南
团队
UMass Dartmouth, Team 3-2, Botvin Fall 2022 UMass Dartmouth, Team 3-2, Botvin Fall 2022 的会员
UMASSD-BOTVIN-F22S3G2
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 68
总计 1,077
