跳转到主内容
Shark Vertex Pro IZ682H Brush Roller Replacement
  1. Shark Vertex Pro IZ682H Brush Roller Replacement, Brush Roller: 步骤 1 中的图像 1,1
    • Detach the power nozzle from the vacuum and turn it so the right side is facing you. Pull down the blue tab to the direction where the arrow is facing.
    • The brush roller should now pop out.
    • Putting the brush roller in again does not require pulling the blue tab. It should pop in with no problem.
结论
Tyree Brooks
于10/26/22注册
486 声望
创作了5篇指南
团队
UMass Dartmouth, Team 3-2, Botvin Fall 2022 UMass Dartmouth, Team 3-2, Botvin Fall 2022 的会员
UMASSD-BOTVIN-F22S3G2
2 名成员
创作了5篇指南
一条评论
Hey there, where can I find the replacement rollers? I have been looking around and I do not see any that name the product exactly or in listed in compatible. Are they standard size or something like that?
John Melo - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 69
总计 994
