跳转到主内容
Shark Vertex Pro IZ682H Brush Roller Belt Replacement
你所需要的
  1. Shark Vertex Pro IZ682H Brush Roller Belt Replacement, Brush Roller: 步骤 1 中的图像 1,1
    • Detach the power nozzle from the vacuum and turn it so the right side is facing you. Pull down the blue tab to the direction where the arrow is facing.
    • The brush roller should now pop out.
    • Putting the brush roller in again does not require pulling the blue tab. It should pop in with no problem.
  2. Shark Vertex Pro IZ682H Brush Roller Belt Replacement, Brush Roller Belt: 步骤 2 中的图像 1,1
    • Turn the three plastic locks to the unlocked position and remove the crevice tool.
    • Use T9 and T15 screwdrivers to remove the seven screws.
  3. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: 步骤 3 中的图像 1,2 Shark Vertex Pro IZ682H Brush Roller Belt Replacement: 步骤 3 中的图像 2,2
    • Use an opening tool on the edges of the casing and pull off the thin plastic coverings on both sides.
    • Expect to hear snapping noises.
    • Pull the plastic coverings off the powerhead.
  4. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: 步骤 4 中的图像 1,1
    • Remove the six screws using a T15 Torx security screwdriver.
    • Remove the plastic headcover.
  5. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: 步骤 5 中的图像 1,1
    • Remove the seven screws using the T10 and T15 Torx security screwdriver.
    • Lift the covering and motor assembly enough to see the belt.
  6. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: 步骤 6 中的图像 1,1
    • Remove the belt and power nozzle.
    • When reinstalling, be sure the belt is tightly secured around the gear grooves.
结论
另外一个人完成了本指南。
Tyree Brooks
于10/26/22注册
486 声望
创作了5篇指南
团队
UMass Dartmouth, Team 3-2, Botvin Fall 2022 UMass Dartmouth, Team 3-2, Botvin Fall 2022 的会员
UMASSD-BOTVIN-F22S3G2
2 名成员
创作了5篇指南
2条评论
Thanks for the instruction. It helped, however, I cannot find the brush anywhere that goes to this vacuum (the one that attaches to the belt)
Eric - 回复
Hey I am looking for the brush. Did you manage to find it or find an alternative?
John Melo -
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 46
过去 30 天: 235
总计 6,384
