跳转到主内容
Shark Vacuum Pet Hair Power Brush Roller Replacement
你所需要的
  1. Shark Vacuum Pet Hair Power Brush Roller Replacement, About the unit: 步骤 1 中的图像 1,2 Shark Vacuum Pet Hair Power Brush Roller Replacement, About the unit: 步骤 1 中的图像 2,2
    • This Shark model brush head consists of 7 parts: a base frame, a gear, a roller brush, two side screws, a plastic round band, and a top frame of the head.
    • Push the grey button on the back panel to open up the brush head.
  2. Shark Vacuum Pet Hair Power Brush Roller Replacement, Disassembly: 步骤 2 中的图像 1,3 Shark Vacuum Pet Hair Power Brush Roller Replacement, Disassembly: 步骤 2 中的图像 2,3 Shark Vacuum Pet Hair Power Brush Roller Replacement, Disassembly: 步骤 2 中的图像 3,3
    • Take the purple gear, belt, and brush out of the body.
    • Save the belt as this is needed to make the unit operate.
  3. Shark Vacuum Pet Hair Power Brush Roller Replacement, Replacing the brush: 步骤 3 中的图像 1,3 Shark Vacuum Pet Hair Power Brush Roller Replacement, Replacing the brush: 步骤 3 中的图像 2,3 Shark Vacuum Pet Hair Power Brush Roller Replacement, Replacing the brush: 步骤 3 中的图像 3,3
    • Pull out the side screws from the right and left side of the old roller brush and put them on the replacement roller brush.
结论
8等其他人完成本指南。
Roshni Sachar
于03/19/16注册
298 声望
撰写一个指南
团队
Michigan Tech, Team 1-23, Lauer Spring 2016 Michigan Tech, Team 1-23, Lauer Spring 2016 的会员
MTU-LAUER-S16S1G23
1 名成员
创作了1篇指南
15条评论
Cat hair will jam up in the small gap between the gear and the bushing on the turbine and will cause enough friction to stop the turbine. I used a needle to dig out the hair and it solved the problem.
hvabrams - 回复
Great tip! It works now! TY!
Wendy Dean -
perfect solution, could find the problem
Pat Gustafson -
Thank you so much for posting this helpful advice… it was the perfect solution to fix exactly what was happening to stop the turbine on the brush accessory for my Shark vacuum. Because I couldn’t find info anywhere else, especially - and frustratingly - the manufacturer’s site, I almost ended up purchasing a replacement part. I so appreciate your suggestion here!
Elizabeth C Lewis -
very clear and concise. took me 5 minutes with your instructions - couldn’t find anything like this on the shark site.
tigersfoot - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 39
过去 30 天: 220
总计 48,003
