跳转到主内容
Shark Ultimate Professional Power Cord Replacement
你所需要的
  1. Shark Ultimate Professional Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,3 Shark Ultimate Professional Power Cord Replacement, Power Cord: 步骤 1 中的图像 2,3 Shark Ultimate Professional Power Cord Replacement, Power Cord: 步骤 1 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the two 11.5mm screws on the back of the iron.
    • Remove the back cover piece.
    • Make sure iron is unplugged and cooled off.
  2. Shark Ultimate Professional Power Cord Replacement: 步骤 2 中的图像 1,2 Shark Ultimate Professional Power Cord Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the two 11.8mm screws holding the white clamp to the iron.
    • Use the Phillips #0 screwdriver to remove the two 6.6mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Power Cord Replacement: 步骤 3 中的图像 1,3 Shark Ultimate Professional Power Cord Replacement: 步骤 3 中的图像 2,3 Shark Ultimate Professional Power Cord Replacement: 步骤 3 中的图像 3,3
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Pull the rubber stopper through the split end of the wire.
    • Pull the wire through the plastic cover.
结论
3等其他人完成本指南。
Drew Carff
于10/23/17注册
868 声望
创作了5篇指南
团队
USF Tampa, Team S1-G4, Leahy Fall 2017 USF Tampa, Team S1-G4, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G4
3 名成员
创作了10篇指南
6条评论
Where can you get a replacement power cord?
dnojokes - 回复
Yes, where can we get cords? I see a lot of people having trouble with shark irons
Betty Gulley - 回复
These instructions are not helpful at all without a source to purchase a replacement cable. Two people have previously asked this question. Can we get a response? I have done extensive searches online for a POLARIZED 16/2 HPN power cable with crimped ring terminals. NON-polarized ones are cheap and readily available. The show up immediately when searching for an iron replacement power cable. That’s not the cable used for this iron, nor is it the cable used in the pictures of this repair. Please tell us where we can purchase the cable, or even tell us you don’t know. Please, don’t just ignore the inquiry.
MDGadget - 回复
Model# GI505-55 uses security T-10 screw used to secure back panel. Suggest testing both conductors for continuity from above white clamp to the ring connectors. This may be the point of failure if the clamp was over-tightened. In this case, the cord can be reused with a loss of 6 inches and crimping of new ring connectors.
Andrew Shamis - 回复
Thank you Andrew!
Ferdinant -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 78
总计 7,932
