跳转到主内容
Shark Ultimate Professional Mode Display Replacement
你所需要的
  1. Shark Ultimate Professional Mode Display Replacement, Mode Display: 步骤 1 中的图像 1,3 Shark Ultimate Professional Mode Display Replacement, Mode Display: 步骤 1 中的图像 2,3 Shark Ultimate Professional Mode Display Replacement, Mode Display: 步骤 1 中的图像 3,3
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
  2. Shark Ultimate Professional Mode Display Replacement: 步骤 2 中的图像 1,2 Shark Ultimate Professional Mode Display Replacement: 步骤 2 中的图像 2,2
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Mode Display Replacement: 步骤 3 中的图像 1,3 Shark Ultimate Professional Mode Display Replacement: 步骤 3 中的图像 2,3 Shark Ultimate Professional Mode Display Replacement: 步骤 3 中的图像 3,3
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside the power cord.
  4. Shark Ultimate Professional Mode Display Replacement: 步骤 4 中的图像 1,3 Shark Ultimate Professional Mode Display Replacement: 步骤 4 中的图像 2,3 Shark Ultimate Professional Mode Display Replacement: 步骤 4 中的图像 3,3
    • Use the Philips head #0 screwdriver to remove remaining 6.58mm screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Wires order (from left to right): Brown, Blue, Black, Red
    • Unclip the black adapter piece on the bottom right.
  5. Shark Ultimate Professional Mode Display Replacement: 步骤 5 中的图像 1,2 Shark Ultimate Professional Mode Display Replacement: 步骤 5 中的图像 2,2
    • Use the Philips head #0 screwdriver to remove two 9.75mm screws (left and right) affixed to circuit board.
  6. Shark Ultimate Professional Mode Display Replacement: 步骤 6 中的图像 1,2 Shark Ultimate Professional Mode Display Replacement: 步骤 6 中的图像 2,2
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Pull the circuit board out from its affixed position.
  7. Shark Ultimate Professional Mode Display Replacement: 步骤 7 中的图像 1,3 Shark Ultimate Professional Mode Display Replacement: 步骤 7 中的图像 2,3 Shark Ultimate Professional Mode Display Replacement: 步骤 7 中的图像 3,3
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
    • Remove and set aside the mode display.
结论
另外一个人完成了本指南。
Drew Carff
于10/23/17注册
868 声望
创作了5篇指南
团队
USF Tampa, Team S1-G4, Leahy Fall 2017 USF Tampa, Team S1-G4, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 651
