跳转到主内容
Shark Ultimate Professional Heat Plate Replacement
你所需要的
  1. Shark Ultimate Professional Heat Plate Replacement, Heat Plate: 步骤 1 中的图像 1,3 Shark Ultimate Professional Heat Plate Replacement, Heat Plate: 步骤 1 中的图像 2,3 Shark Ultimate Professional Heat Plate Replacement, Heat Plate: 步骤 1 中的图像 3,3
    • Remove the two screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure iron is unplugged and cooled off.
  2. Shark Ultimate Professional Heat Plate Replacement: 步骤 2 中的图像 1,2 Shark Ultimate Professional Heat Plate Replacement: 步骤 2 中的图像 2,2
    • Remove the two screws holding the white clamp to the iron.
    • Remove the two screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Heat Plate Replacement: 步骤 3 中的图像 1,1
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside power cord.
  4. Shark Ultimate Professional Heat Plate Replacement: 步骤 4 中的图像 1,3 Shark Ultimate Professional Heat Plate Replacement: 步骤 4 中的图像 2,3 Shark Ultimate Professional Heat Plate Replacement: 步骤 4 中的图像 3,3
    • Remove remaining screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Red, Black
  5. Shark Ultimate Professional Heat Plate Replacement: 步骤 5 中的图像 1,2 Shark Ultimate Professional Heat Plate Replacement: 步骤 5 中的图像 2,2
    • Remove two screws (left and right) affixed to circuit board.
结论
3等其他人完成本指南。
Drew Carff
于10/23/17注册
868 声望
创作了5篇指南
团队
USF Tampa, Team S1-G4, Leahy Fall 2017 USF Tampa, Team S1-G4, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G4
3 名成员
创作了10篇指南
3条评论
This is an incomplete guide. Why even put it up. So silly and ridiculous. Not Good at all.
Muhammad Ahmad - 回复
Where is the part about the heat plate?
Nealy Moxam - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 28
总计 2,047
