跳转到主内容
Shark Ultimate Professional Circuit Board Replacement
你所需要的
  1. Shark Ultimate Professional Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 1,3 Shark Ultimate Professional Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 2,3 Shark Ultimate Professional Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 3,3
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
  2. Shark Ultimate Professional Circuit Board Replacement: 步骤 2 中的图像 1,2 Shark Ultimate Professional Circuit Board Replacement: 步骤 2 中的图像 2,2
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Pull the split end of the power cord upward through the ball joint.
    • Set aside the power cord.
  4. Shark Ultimate Professional Circuit Board Replacement: 步骤 4 中的图像 1,3 Shark Ultimate Professional Circuit Board Replacement: 步骤 4 中的图像 2,3 Shark Ultimate Professional Circuit Board Replacement: 步骤 4 中的图像 3,3
    • Use the Philips head #0 screwdriver to remove the remaining 6.58mm screws that hold the wires on the bottom (brown and blue).
    • Remove from left to right
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Red, Black
  5. Shark Ultimate Professional Circuit Board Replacement: 步骤 5 中的图像 1,2 Shark Ultimate Professional Circuit Board Replacement: 步骤 5 中的图像 2,2
    • Use the Philips head #0 screwdriver to remove the two 9.75mm screws (left and right) affixed to the circuit board.
  6. Shark Ultimate Professional Circuit Board Replacement: 步骤 6 中的图像 1,2 Shark Ultimate Professional Circuit Board Replacement: 步骤 6 中的图像 2,2
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Gently pull the circuit board from affixed position.
    • The circuit board will not be completely separated at this point.
  7. Shark Ultimate Professional Circuit Board Replacement: 步骤 7 中的图像 1,3 Shark Ultimate Professional Circuit Board Replacement: 步骤 7 中的图像 2,3 Shark Ultimate Professional Circuit Board Replacement: 步骤 7 中的图像 3,3
    • Remove the mode display piece and set aside.
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
  8. Shark Ultimate Professional Circuit Board Replacement: 步骤 8 中的图像 1,1
    • Remove the connecting wire from the connected adapter in the handle by pulling lightly.
    • Set aside the circuit board.
结论
5等其他人完成本指南。
Drew Carff
于10/23/17注册
868 声望
创作了5篇指南
团队
USF Tampa, Team S1-G4, Leahy Fall 2017 USF Tampa, Team S1-G4, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G4
3 名成员
创作了10篇指南
4条评论
My shark 1505C does not have philips screws on the back. They are security torx and I cannot find a tool to open it.
Where can I buy a main board for this iron ?
Thanks
NevG.
nevstarg - 回复
where do I buy it's circuit board?
egovieira - 回复
Where can u buy the circuit board professional 1800 version?
Astinder Singhera - 回复
How much does the circuit board cost? and where can i purchase it?
D.A. Willis - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 39
总计 3,098
