简介
This guide will inform users how to replace their Shark Steam Pocket Mop's Water Tank / Bladder.
你所需要的
Begin by removing the 8 quarter inch phillips head screws found along the back panel
Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
Start by gently moving the midframe from the top portion of the panel to expose the bottom portion of the mop's water tank / bladder.
Remove the 10 quarter inch phillips head screws from the bottom portion of the water tank / bladder.
Then gently lift the water tank / bladder out of its plastic housing. and turn it over.
To fully remove the water tank / bladder, use your tweezers to remove the metal ring that keeps the hose fastened to the plastic tank.
