跳转到主内容
Shark Steam Pocket Mop Power Cable Replacement
你所需要的
  1. Shark Steam Pocket Mop Power Cable Replacement, Back Panel: 步骤 1 中的图像 1,3 Shark Steam Pocket Mop Power Cable Replacement, Back Panel: 步骤 1 中的图像 2,3 Shark Steam Pocket Mop Power Cable Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Power Cable Replacement, Power Cable: 步骤 2 中的图像 1,2 Shark Steam Pocket Mop Power Cable Replacement, Power Cable: 步骤 2 中的图像 2,2
    • Start by removing the two 1/8th inch Phillips head screws with your Phillips head screwdriver.
    • Gently remove the small plastic piece holding the wires against the plastic midframe of the mop.
    • Next use your wire cutters to remove the two plastic connectors and replace those wires with your new ones.
结论
Jacob Howe
于10/10/17注册
549 声望
创作了5篇指南
团队
USF Tampa, Team S13-G7, Cagle Fall 2017 USF Tampa, Team S13-G7, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G7
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 28
总计 1,712
