跳转到主内容
Shark Steam Pocket Mop Ejection Button Assembly Replacement
你所需要的
  1. Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: 步骤 1 中的图像 1,3 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: 步骤 1 中的图像 2,3 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: 步骤 2 中的图像 1,3 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: 步骤 2 中的图像 2,3 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: 步骤 2 中的图像 3,3
    • Begin by removing the two quarter inch Phillips head screws you see pictured. These screws hold the bottom part of the button assembly to the Mop's midframe.
    • Be very careful not to lose the spring that is in between the top and bottom part of the button assembly.
  3. Shark Steam Pocket Mop Ejection Button Assembly Replacement: 步骤 3 中的图像 1,2 Shark Steam Pocket Mop Ejection Button Assembly Replacement: 步骤 3 中的图像 2,2
    • Once the bottom piece of the assembly has been removed, carefully turn the mop over and move the front panel of the mop to the side
    • Once you've turned your device over you should be able to remove the top portion of the button assembly with ease. It should not require anything more than your fingers.
结论
另外一个人完成了本指南。
Jacob Howe
于10/10/17注册
549 声望
创作了5篇指南
团队
USF Tampa, Team S13-G7, Cagle Fall 2017 USF Tampa, Team S13-G7, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G7
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 18
总计 327
