跳转到主内容
Shark Rotator Slim-Light Lift-Away Upright Motor Replacement
你所需要的
  1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: 步骤 1 中的图像 1,2 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: 步骤 1 中的图像 2,2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 步骤 2 中的图像 1,3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 步骤 2 中的图像 2,3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 步骤 2 中的图像 3,3
    • Remove the two 19mm Phillips #2 screws located in the red plastic piece behind the filter.
  3. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 步骤 3 中的图像 1,3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 步骤 3 中的图像 2,3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 步骤 3 中的图像 3,3
    • Flip over vacuum and remove the six 12.7mm Phillips #2 screws from the base.
    • Take off white plastic cover exposing the motor in its insulation.
  4. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 步骤 4 中的图像 1,3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 步骤 4 中的图像 2,3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 步骤 4 中的图像 3,3
    • Remove the motor from the base and slide the insulation down along the wires.
    • Find the plastic caps on top of the black and white wires. Using pliers twist and carefully remove these caps.
    • Needle nosed pliers are recommended but not necessary.
    • These plastic caps are somewhat sensitive and can be difficult to take off. Additionally once taken off they can become unusable.
结论
另外一个人完成了本指南。
Joshua Morrison
于01/24/19注册
196 声望
创作了2篇指南
团队
Cal Poly, Team S19-G3, White Winter 2019 Cal Poly, Team S19-G3, White Winter 2019 的会员
CPSU-WHITE-W19S19G3
5 名成员
创作了12篇指南
一条评论
What is the motor PN and where can I get one?
Dennis Meece - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 29
总计 1,460
