跳转到主内容
Shark Rotator Powered Lift-Away Suction Hose Replacement
你所需要的
  1. Shark Rotator Powered Lift-Away Suction Hose Replacement, Remove the Top portion of the Suction Hose: 步骤 1 中的图像 1,2 Shark Rotator Powered Lift-Away Suction Hose Replacement, Remove the Top portion of the Suction Hose: 步骤 1 中的图像 2,2
    • On the top portion of the suction hose, firmly press the tab.
    • Next, pull the suction hose up to detach it.
  2. Shark Rotator Powered Lift-Away Suction Hose Replacement, Remove the Bottom portion of the Hose: 步骤 2 中的图像 1,2 Shark Rotator Powered Lift-Away Suction Hose Replacement, Remove the Bottom portion of the Hose: 步骤 2 中的图像 2,2
    • On the bottom portion of the suction hose, press the tab and pull the hose out.
结论
2等其他人完成本指南。
团队
Cal Poly, Team S9-G3, Banghart Fall 2017 Cal Poly, Team S9-G3, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S9G3
4 名成员
创作了12篇指南
一条评论
Base of vac has tear in
Missy McCuthen - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 21
总计 2,245
