简介
The roller brush can have debris that will cause the vacuum to not work properly. It is important that you always clean your roller brush after every use, so that your Shark Rotator Powered Lift Away Speed Vacuum can perform at it's best. This guide will show you how to change your roller brush if it becomes damaged or is broken.
你所需要的
10等其他人完成本指南。
13条评论
Exactly, I struggled for sometime trying to find that 1 little screw that was a Phillips head.
I figured out how to get it apart… Where do I find a new roller?
where can i get a new roller also...
