跳转到主内容
Shark Rotator Powered Lift-Away Roller Brush Replacement
你所需要的
  1. Shark Rotator Powered Lift-Away Roller Brush Replacement, Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 1 中的图像 1,2 Shark Rotator Powered Lift-Away Roller Brush Replacement, Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 1 中的图像 2,2
    • Push the lift away button and pull the handle up to separate the body from the wand section.
  2. Shark Rotator Powered Lift-Away Roller Brush Replacement: 步骤 2 中的图像 1,1
    • Push lift away button on the wand then lift up on the top section to separate.
  3. Shark Rotator Powered Lift-Away Roller Brush Replacement: 步骤 3 中的图像 1,2 Shark Rotator Powered Lift-Away Roller Brush Replacement: 步骤 3 中的图像 2,2
    • Tilt the wand shaft backwards for convenient.
  4. Shark Rotator Powered Lift-Away Roller Brush Replacement: 步骤 4 中的图像 1,2 Shark Rotator Powered Lift-Away Roller Brush Replacement: 步骤 4 中的图像 2,2
    • Lay the head nozzle piece upside down.
    • Rotate the three gray taps to the unlock position.
  5. Shark Rotator Powered Lift-Away Roller Brush Replacement: 步骤 5 中的图像 1,1
    • With your fingers, pry and pull the brush cage open.
  6. Shark Rotator Powered Lift-Away Roller Brush Replacement: 步骤 6 中的图像 1,2 Shark Rotator Powered Lift-Away Roller Brush Replacement: 步骤 6 中的图像 2,2
    • Remove the 13 screws (circled in yellow) using a phillips screwdriver.
    • Be sure to keep track of which screws go into which hole.
    • Remove the one screw (circled in red) that has a Torx head (might be Phillips head on some models).
    • The Torx screw is hidden under a rubber gasket. Carefully, lift up the gasket without damaging it to access this screw.
    • Remove the horizontal screw (circled in orange) that attaches the gray side panel (necessary to remove the white cap on the roller brush in step 8)
  7. Shark Rotator Powered Lift-Away Roller Brush Replacement: 步骤 7 中的图像 1,1
    • Lift up the top cover now that all of the screws have been removed.
  8. Shark Rotator Powered Lift-Away Roller Brush Replacement, Roller Brush: 步骤 8 中的图像 1,1
    • Remove white cap with a Flathead screwdriver or any other wedge-like tool.
  9. Shark Rotator Powered Lift-Away Roller Brush Replacement: 步骤 9 中的图像 1,3 Shark Rotator Powered Lift-Away Roller Brush Replacement: 步骤 9 中的图像 2,3 Shark Rotator Powered Lift-Away Roller Brush Replacement: 步骤 9 中的图像 3,3
    • Gently push piece in.
    • Pull piece down and out of the container.
  10. Shark Rotator Powered Lift-Away Roller Brush Replacement: 步骤 10 中的图像 1,1
    • Turn vacuum head over to remove brush.
结论
12等其他人完成本指南。
Cameron Ngai
于09/27/17注册
718 声望
创作了3篇指南
团队
Cal Poly, Team S9-G3, Banghart Fall 2017 Cal Poly, Team S9-G3, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S9G3
4 名成员
创作了12篇指南
19条评论
Where do you get the rotator brush? All I can find are the two for the Navigator.
Dave - 回复
Same. Need a new brush bar.
Michael Brennan - 回复
I appreciate the info you had posted. It was easy to follow and helped me to save money on buying a new vacuum!
Ah Sum Taeza - 回复
I have the same question. Where can I find the brushbar to the Shark Rotator Professional lift-away mv650?
i’m getting a little frustrated because my carpet’s pile is not getting lifted and cleaned.
Venette
7 August 2019
crazeeincc - 回复
Does anyone get a reply?
crazeeincc - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 133
过去 30 天: 693
总计 45,015
