跳转到主内容
Shark Rotator Powered Lift-Away Head Nozzle Disassembly
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Shark Rotator Powered Lift-Away Head Nozzle Disassembly, Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 1 中的图像 1,2 Shark Rotator Powered Lift-Away Head Nozzle Disassembly, Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 1 中的图像 2,2
    • Push the lift away button and pull the handle up to separate the body from the wand section.
  2. Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 2 中的图像 1,1
    • Push lift away button on the wand then lift up on the top section to separate.
  3. Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 3 中的图像 1,2 Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 3 中的图像 2,2
    • Tilt the wand shaft backwards for convenient.
  4. Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 4 中的图像 1,2 Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 4 中的图像 2,2
    • Lay the head nozzle piece upside down.
    • Rotate the three gray taps to the unlock position.
  5. Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 5 中的图像 1,1
    • With your fingers, pry and pull the brush cage open.
  6. Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 6 中的图像 1,2 Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 6 中的图像 2,2
    • Remove the 13 screws (circled in yellow) using a phillips screwdriver.
    • Be sure to keep track of which screws go into which hole.
    • Remove the one screw (circled in red) that has a Torx head (might be Phillips head on some models).
    • The Torx screw is hidden under a rubber gasket. Carefully, lift up the gasket without damaging it to access this screw.
    • Remove the horizontal screw (circled in orange) that attaches the gray side panel (necessary to remove the white cap on the roller brush in step 8)
  7. Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 7 中的图像 1,1
    • Lift up the top cover now that all of the screws have been removed.
结论
另外一个人完成了本指南。
Dan lee
于09/27/17注册
101 声望
撰写一个指南
团队
Cal Poly, Team S9-G3, Banghart Fall 2017 Cal Poly, Team S9-G3, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S9G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 67
