跳转到主内容
Shark Rotator Powered Lift-Away Brush Belt Replacement
你所需要的
  1. Shark Rotator Powered Lift-Away Brush Belt Replacement, Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 1 中的图像 1,2 Shark Rotator Powered Lift-Away Brush Belt Replacement, Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 步骤 1 中的图像 2,2
    • Push the lift away button and pull the handle up to separate the body from the wand section.
  2. Shark Rotator Powered Lift-Away Brush Belt Replacement: 步骤 2 中的图像 1,1
    • Push lift away button on the wand then lift up on the top section to separate.
  3. Shark Rotator Powered Lift-Away Brush Belt Replacement: 步骤 3 中的图像 1,2 Shark Rotator Powered Lift-Away Brush Belt Replacement: 步骤 3 中的图像 2,2
    • Tilt the wand shaft backwards for convenient.
  4. Shark Rotator Powered Lift-Away Brush Belt Replacement: 步骤 4 中的图像 1,2 Shark Rotator Powered Lift-Away Brush Belt Replacement: 步骤 4 中的图像 2,2
    • Lay the head nozzle piece upside down.
    • Rotate the three gray taps to the unlock position.
  5. Shark Rotator Powered Lift-Away Brush Belt Replacement: 步骤 5 中的图像 1,1
    • With your fingers, pry and pull the brush cage open.
  6. Shark Rotator Powered Lift-Away Brush Belt Replacement: 步骤 6 中的图像 1,2 Shark Rotator Powered Lift-Away Brush Belt Replacement: 步骤 6 中的图像 2,2
    • Remove the 13 screws (circled in yellow) using a phillips screwdriver.
    • Be sure to keep track of which screws go into which hole.
    • Remove the one screw (circled in red) that has a Torx head (might be Phillips head on some models).
    • The Torx screw is hidden under a rubber gasket. Carefully, lift up the gasket without damaging it to access this screw.
    • Remove the horizontal screw (circled in orange) that attaches the gray side panel (necessary to remove the white cap on the roller brush in step 8)
  7. Shark Rotator Powered Lift-Away Brush Belt Replacement: 步骤 7 中的图像 1,1
    • Lift up the top cover now that all of the screws have been removed.
  8. Shark Rotator Powered Lift-Away Brush Belt Replacement, Brush Belt: 步骤 8 中的图像 1,1
    • Pry tab out with a flat head screwdriver or any wedge-like tool.
  9. Shark Rotator Powered Lift-Away Brush Belt Replacement: 步骤 9 中的图像 1,3 Shark Rotator Powered Lift-Away Brush Belt Replacement: 步骤 9 中的图像 2,3 Shark Rotator Powered Lift-Away Brush Belt Replacement: 步骤 9 中的图像 3,3
    • Gently press in on brush to detach.
    • Pull brush down and out.
  10. Shark Rotator Powered Lift-Away Brush Belt Replacement: 步骤 10 中的图像 1,1
    • Slide the belt off of the gear.
结论
6等其他人完成本指南。
Cameron Ngai
于09/27/17注册
718 声望
创作了3篇指南
团队
Cal Poly, Team S9-G3, Banghart Fall 2017 Cal Poly, Team S9-G3, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S9G3
4 名成员
创作了12篇指南
一条评论
where did you get new belts? I bought a set from Amazon for a Shark NV752 and the belts are a bit to large.
John Doe - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 28
过去 30 天: 95
总计 14,954
