跳转到主内容
Shark Rotator NV502 Roller Brush Motor Replacement
你所需要的
  1. Shark Rotator NV502 Roller Brush Motor Replacement, Roller Brush: 步骤 1 中的图像 1,2 Shark Rotator NV502 Roller Brush Motor Replacement, Roller Brush: 步骤 1 中的图像 2,2
    • Pull the handle while pressing the lift away button to remove the body of the vacuum.
  2. Shark Rotator NV502 Roller Brush Motor Replacement: 步骤 2 中的图像 1,2 Shark Rotator NV502 Roller Brush Motor Replacement: 步骤 2 中的图像 2,2
    • Flip the base of the vacuum over to access the bottom.
    • Remove the two small wheels with a metal spudger.
  3. Shark Rotator NV502 Roller Brush Motor Replacement: 步骤 3 中的图像 1,2 Shark Rotator NV502 Roller Brush Motor Replacement: 步骤 3 中的图像 2,2
    • Remove the nine 16 mm screws using the Phillips #2 Screwdriver. Press on the side tabs in the middle of the panel and pull up to reveal the screw under the hose connection.
    • Remove the two 13.5 mm screws using the Phillips #2 Screwdriver.
  4. Shark Rotator NV502 Roller Brush Motor Replacement: 步骤 4 中的图像 1,2 Shark Rotator NV502 Roller Brush Motor Replacement: 步骤 4 中的图像 2,2
    • Pull up on the cover and move it to the side.
    • Remove the wire attached to the base by squeezing the pin and pulling up.
  5. Shark Rotator NV502 Roller Brush Motor Replacement: 步骤 5 中的图像 1,2 Shark Rotator NV502 Roller Brush Motor Replacement: 步骤 5 中的图像 2,2
    • Remove the two 11 mm screws using the Phillips #2 screwdriver.
    • Lift the roller brush cover up.
  6. Shark Rotator NV502 Roller Brush Motor Replacement: 步骤 6 中的图像 1,1
    • Pull out the roller brush.
  7. Shark Rotator NV502 Roller Brush Motor Replacement, Roller Belt: 步骤 7 中的图像 1,2 Shark Rotator NV502 Roller Brush Motor Replacement, Roller Belt: 步骤 7 中的图像 2,2
    • Remove the roller belt from around the roller brush and the motor gear.
  8. Shark Rotator NV502 Roller Brush Motor Replacement, Roller Brush Motor: 步骤 8 中的图像 1,2 Shark Rotator NV502 Roller Brush Motor Replacement, Roller Brush Motor: 步骤 8 中的图像 2,2
    • Lift the motor out of the base.
    • Disconnect the pins attaching the wires to the motor by pulling on the pins.
结论
3等其他人完成本指南。
Caroline Swanson
于10/05/16注册
1,372 声望
创作了3篇指南
团队
Cal Poly, Team 4-3, Livingston Fall 2016 Cal Poly, Team 4-3, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G3
4 名成员
创作了19篇指南
6条评论
Any idea where to get a replacement control board for a NV501 machine? Brush motor checks out, but no power going to brush motor (though vacuum suction is fine).
Dave H - 回复
Any idea where to get a replacement control board for the NV501?
Dave H - 回复
Did you ever find a board, Dave?
Aaron king -
Wife took all apart; quite impressed - but what voltage does beater motor run at? Gotta get a multimeter which are cheap now; Ck red and white leads to cute little motor; and if no power is reaching motor i’ll have the same question as DAVE… and also need to find part (and price of part) if it’s fhe motor …
outdoorjanitorial - 回复
I’m in the same boat here, Pretty sure my brush motor is going out. It keeps stuttering. I’ve cleaned everything but the filters. If cleaned filters don’t fix the problem, which I don’t know why they would, I need to buy a new brush motor. I don’t want to trash a vacuum only because of a easy to replace motor piece. If anyone finds where to buy it let us know!
FangerZero -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 30
总计 8,282
