跳转到主内容
Shark Rotator NV502 Foam Filter Replacement
  1. Shark Rotator NV502 Foam Filter Replacement, Foam Filter: 步骤 1 中的图像 1,1
    • Locate and press the tab on the top of the removable canister.
    • Lift the canister away from the body of the vacuum.
  2. Shark Rotator NV502 Foam Filter Replacement: 步骤 2 中的图像 1,1
    • Look inside the tall hole to locate the foam filter inside.
    • Pull out the foam filter.
  3. Shark Rotator NV502 Foam Filter Replacement: 步骤 3 中的图像 1,1
    • Remove the felt filter just below the foam filter
    • Clean or Replace the filters. Let the filter dry before reinserting.
结论
Samuel
于10/06/16注册
307 声望
创作了3篇指南
团队
Cal Poly, Team 4-3, Livingston Fall 2016 Cal Poly, Team 4-3, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G3
4 名成员
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 1,964
