跳转到主内容
Shark Rotator Lift-Away Speed Brushroll Motor Replacement
你所需要的
  1. Shark Rotator Lift-Away Speed Brushroll Motor Replacement, Brushroll: 步骤 1 中的图像 1,1
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Locate the release button at the top of the vacuum pod next to the handle.
    • Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
    • Removing the pod is optional, but it may be easier to locate blockages or access the motor and belt if you do so.
  2. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 步骤 2 中的图像 1,2 Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 步骤 2 中的图像 2,2
    • Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
  3. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 步骤 3 中的图像 1,2 Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 步骤 3 中的图像 2,2
    • Lift the brushroll out by using the pull-tab on the left side.
    • You can test the brushroll once it has been inserted by plugging the vacuum in and running the vacuum in carpet mode. The brushroll indicator light should be a solid green color.
  4. Shark Rotator Lift-Away Speed Brushroll Motor Replacement, Brushroll Motor: 步骤 4 中的图像 1,1
    • Remove the five 5mm Torx #9 screws on the front side.
  5. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 步骤 5 中的图像 1,1
    • Remove the six 7.5mm Torx #20 screws on the bottom face of the nozzle.
    • A screwdriver extension may be necessary to reach the screw closest to the center of the nozzle.
  6. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 步骤 6 中的图像 1,1
    • Remove the top panel by lifting the top piece off of the bottom.
    • There will be loud clicking noises.
  7. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 步骤 7 中的图像 1,1
    • If you are trying to remove the belt, you may skip to the next step.
    • Remove the 7.5mm Torx #20 screw in front of the motor.
    • The motor is the gray block on the right side of the floor nozzle (when the nozzle faces towards you).
  8. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 步骤 8 中的图像 1,2 Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 步骤 8 中的图像 2,2
    • Remove the panel to reveal the motor screw.
    • Remove the 7.5mm Torx #20 motor screw.
    • Remove the motor.
结论
Weston Mongomery
于10/02/17注册
201 声望
创作了2篇指南
团队
Cal Poly, Team S15-G7, Livingston Fall 2017 Cal Poly, Team S15-G7, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S15G7
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 30
总计 3,760
