跳转到主内容
Shark Rocket Professional Secondary Filters Replacement
  1. Shark Rocket Professional Secondary Filters Replacement, Dust Cup: 步骤 1 中的图像 1,2 Shark Rocket Professional Secondary Filters Replacement, Dust Cup: 步骤 1 中的图像 2,2
    • First, locate the button that says "Dust Cup". It is right next to the power button at the base of the handle.
    • Press the button down completely; you should feel a click.
  2. Shark Rocket Professional Secondary Filters Replacement: 步骤 2 中的图像 1,1
    • Grab the handle of the dust cup, then pull up and away from the vacuum.
    • You must press the button and pull the dust cap simultaneously at first to release the latch.
  3. Shark Rocket Professional Secondary Filters Replacement, Secondary Filters: 步骤 3 中的图像 1,3 Shark Rocket Professional Secondary Filters Replacement, Secondary Filters: 步骤 3 中的图像 2,3 Shark Rocket Professional Secondary Filters Replacement, Secondary Filters: 步骤 3 中的图像 3,3
    • As you look beneath the base of the dust cup, you will see a white foam filter. Remove this filter with your fingers.
  4. Shark Rocket Professional Secondary Filters Replacement: 步骤 4 中的图像 1,1
    • Removing the first filter will reveal a second, thicker foam filter. Remove this as well.
    • Shark recommends that you rinse and air dry these filters monthly.
    • Remember to replace the filters in the correct order.
  5. Shark Rocket Professional Secondary Filters Replacement: 步骤 5 中的图像 1,1
    • A dust filter is located within the dust cup. To access it, open the dust cup by pressing the orange tab on the front and pulling up on the handle.
  6. Shark Rocket Professional Secondary Filters Replacement: 步骤 6 中的图像 1,1
    • Find the cylindrical screen in the center of the dust cap, grab the top, and pull it straight out.
    • If this filter is dirty, shake it or rinse it off to clean it.
结论
另外一个人完成了本指南。
Theo Watkins
于01/23/18注册
356 声望
创作了2篇指南
团队
Cal Poly, Team S18-G6, Livingston Winter 2018 Cal Poly, Team S18-G6, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S18G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 72
总计 5,905
