跳转到主内容
Shark Rocket Professional Hose Replacement
你所需要的
  1. Shark Rocket Professional Hose Replacement, Main Hose: 步骤 1 中的图像 1,3 Shark Rocket Professional Hose Replacement, Main Hose: 步骤 1 中的图像 2,3 Shark Rocket Professional Hose Replacement, Main Hose: 步骤 1 中的图像 3,3
    • Look at the Shark Rocket Professional's Extension Rod.
    • Identify where the hose connects to the main body of the vacuum.
    • Press the tabs on the sides of the connector to remove the hose.
    • You can use a long, thin object to unclog the hose.
    • If this fixes your problem, then you are finished with this guide.
  2. Shark Rocket Professional Hose Replacement: 步骤 2 中的图像 1,2 Shark Rocket Professional Hose Replacement: 步骤 2 中的图像 2,2
    • Look at the vacuum handle and locate the orange button that says "Handle" with a picture of a lock.
    • Press the button and remove the handle.
  3. Shark Rocket Professional Hose Replacement: 步骤 3 中的图像 1,2 Shark Rocket Professional Hose Replacement: 步骤 3 中的图像 2,2
    • Look at the vacuum handle.
    • Using a T-15 screwdriver, remove the five 15mm screws in the handle by turning them counter-clockwise.
  4. Shark Rocket Professional Hose Replacement: 步骤 4 中的图像 1,3 Shark Rocket Professional Hose Replacement: 步骤 4 中的图像 2,3 Shark Rocket Professional Hose Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool to pry open the handle.
    • Don't worry if the handle sounds like it is going to break; it takes a lot of force to pull apart.
    • When popping open your handle, the small grey piece of plastic(pictured in the last frame) will fly out.
  5. Shark Rocket Professional Hose Replacement: 步骤 5 中的图像 1,3 Shark Rocket Professional Hose Replacement: 步骤 5 中的图像 2,3 Shark Rocket Professional Hose Replacement: 步骤 5 中的图像 3,3
    • The orange plastic piece may have naturally fallen out at this point.
    • Look a your handle.
    • Using your hands, pull the tube from the nozzle of the handle.
    • The tube is soldered onto a wire connecting to the plastic orange piece inside the handle.
    • Cut this connection with wire clippers to remove and replace your tube.
结论
2等其他人完成本指南。
Brad Iglesia
于01/24/18注册
316 声望
创作了2篇指南
团队
Cal Poly, Team S18-G6, Livingston Winter 2018 Cal Poly, Team S18-G6, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S18G6
4 名成员
创作了10篇指南
4条评论
How about an expla8nation about how t9 actually do the lower the hose inside the brush head
Jonathan Hill - 回复
How do you replace the hose in the beater head
daveve2 -
Thank you for this, this guide helped a ton.
Bradlee Johnson - 回复
How long does it take to answer acquestion?
daveve2 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 35
总计 5,867
